All number going to zero, help
This link wants the decryption key.
https://mega.nz/#F!1skByKBZ!dvQTuuT-arigQtq9OeZGhQThis link wants the decryption key.
They do increment when the code is run in the simulator.Looking at the code it looks like there should be some keys (Or a keyboard.) for setting the time. This MAY be preventing the counters incrementing. See what happens if you modify the code so that it puts some values in the hours and minutes counters instead of clearing them at the start of the program. This will help to confirm that the multiplexing is working. If the values that you load display correctly then I think the ISR is not incrementing the time registers.
Les.
