Here are some application notes:hi, would there be any chance of you drawing a rough circuit diagram of exactly what you mean? thanks
I would suggest to try a voltage divider.the output from the pressure sensor is 30mv/psi, i was wondering if i used a 741cn op-amp as an attenuator, could i reduce this output to 1mv/psi to correspond to my digital display?
G | BMP280 Digital Pressure Sensor | Microcontrollers | 6 | |
C | Digital Pressure sensor need help | Sensor Design & Implementation | 9 | |
D | Gas pressure guage (Digital) | Sensor Design & Implementation | 7 | |
H | Digital Blood Pressure Monitor DESIGN HELP | Programming & Languages | 1 | |
H | Digital Blood Pressure Monitor DESIGN HELP | Microcontrollers | 6 |
