Hello Guys,
Im a master student in Design and Engineering and I'm designing a product but unfortunately I dont have enough information about electronic components and I want you to confirm the possibility of this idea or give me better solution.
I tried to make a diagram block that I want you to check it if it needs to change sth.
I explain about my idea:
it should work with ibeacons and application ( through the cloud).
so in the main device, i need the main board which can be programmable with android and bluetooth and wireless is integrated to the board.
I chose raspberry pi module
O i need to find the right power supply. can you please help me even in this case?
If you need more information, pleas let me know
Shirin
Shirin
