schmitt trigger
- Joined Jul 12, 2010
- 2,244
Correct!
That is until the engineers at Ampex figured out the rotating helical-scan head.
Actually, what AMPEX (an acronym, so all caps) figured out is transverse scan. It was wildly impractical to move the tape past the heads at the necessary speeds, so they decided to move the heads past the tape.Correct!
The headwheel has four heads 90 degrees apart. The plane of rotation is 90 degrees from the direction of tape travel. Rotation is 14,400 RPM, so while tape speed is 15 inches per second, the head-to-tape speed is around 100x that. The track angle is very close to 90 degrees. One scan of a head across 2" of tape records/plays a little over 16 lines of video. The tape is sucked up against a circular guide that matches the radius of the headwheel. A VTR requires a vacuum pump to operate.
AMPEX uses rotary transformers to couple the record and play signals, while RCA (the meatball) uses brushes. RCA and early AMPEX machines have high-impedance video heads that require frequency and Q compensation adjustments for each tape. 3rd and 4th gen AMPEX machines use low impedance heads that eliminate both adjustments.
Another thing AMPEX figured out was that even the best ball bearings had too much play, which showed up as an amplitude modulation of the FM carrier caused by radial movement, plus a phase modulation caused by axial movement. Both of these were almost completely eliminated by going to compressed air bearings, so besides the vacuum pump, a quadraplex video recorder also requires compressed air. We eliminated the vacuum pumps by picking off some of the compressed air for a venturi vacuum generator for the female guide.
https://en.wikipedia.org/wiki/Quadruplex_videotape
Various companies in Japan worked out the early helical scan system, turning it into the EIAJ standard. In the US, IVC developed the 9000 helical scan machine. It pulled 2" tape and made broadcast-legal video in both regular and still-frame playback. It did not do well in the US market, but better in Europe.
You have great knowledge on the professional video recorderes , the size of large fridge freezers.
In round numbers, 3 feet by 4 feet by 6 feet, 1/2 ton. Everything from grunt linear power supplies to a 10 MHz FM signal system, plus voltage-variable, baseband video analog delay lines, plus multiple overlapping servo systems, and two motor drive amplifiers. Except for high voltage transmission lines, it is the world of EE in one big analog box. This is where I worked my way through school - EE classes during the day, and a room with seventeen (!!!!!) video machines at night. Absolute EE candy-land.You have great knowledge on the professional video recorders , the size of large fridge freezers.
VHS decks started out with two heads on the drum, but added more as quality improved - flying erase heads for editing, separate record and play heads, etc.Think consumer machines had heads at more like 45 degrees
The speed of the head was used to create an air cushion; the head did not touch the tape, or touched it very lightly. Consumer machines (3/4" U-Matic, 1/2" VHS and BETA, etc.) all have mechanical tape tension systems. Toward the end of the quad era, AMPEX produced the AVR-1. This monster had dual vacuum columns to maintain tape tension, and ***no pinch roller***.and used the speed of the head to hold the tape tight .
If the OP has a quad deck, I'm on the next plane out of here.I assume the op has a consumer machine .
Death trap video.My recollection was about how exciting a tape spill would be.
TS. Thread Starternot sure what TS stands for, but that's pro'ly me. got caught in a whirlwind of other projects, but turning back to this one for the time being. basically the idea is to inject a composite signal into one side of the removed, non-rotating head...and pick up the signal on the other side and amplify it back to a "normal" usable composite video on the other half of the head...then, experiment with all sorts of devices to alter the stable transmission across the coils with such things as magnets, speakers, etal...and see if i can drum up some interesting distortions in a truly analog, hands-on way. something to pass the time until the next world cup game . 8o)
Video is not recorded the same way as audio. The video heads are designed to work with a modulated FM carrier, not baseband video.basically the idea is to inject a composite signal into one side of the removed, non-rotating head...and pick up the signal on the other side and amplify it back to a "normal" usable composite video on the other half of the head..
the two sides of the cylinder can be separated...top and bottom. the heads are spinning on the top side while the bottom side is stationary. the video signal seems to be transmitted by two similar antennae...quite a tech marvel if you ask me. i am guessing it is basically, the two sides of the head, without any other parts if the vcr attached could be used as a short distance video transmitter and reciever....hopefully that clears up the two-sides.
Also, what do you mean by "one side" and "the other side" of a video head.
