differential opamp questions
Santa klaus
Joined Nov 16, 2014
36
the circuit below is a simple differential amplifier used for current sensing. I know how it works however i had 2 questions.
-what is the purpose of capacitor C1
-why is there a resistor and capacitor on the output
My guess is the resistor is needed to drive the MCU's ADC pin with a high enough source impedance to have the right ADC conversion rate;
Can someone help me clarify this ?
wayneh
Joined Sep 9, 2010
18,184
Both questions relate to filtering out noise. The simulation may not do a good job of simulating noise, but it's definitely a real-world concern. You might try injecting some high-frequency noise onto the inputs, so you can see how the circuit behaves with and without C1, C2 and R7.
Sensacell
Joined Jun 19, 2012
3,789
Both RC circuits for low-pass filters.
The input cap is probably to suppress RF interference, the output cap provides additional suppression of high frequency garbage.
