I have been away due to overtime.
Euclid was the gold standard until the early 1800's. At that time geometers found that they could build consistent geometries by starting with contradictory forms of the parallel postulate. This brought into question the platonic conception that mathematics is a description of reality. (There are certainly not contradictory truths in reality.) The development of calculus also brought up some issues. After a century of work, the mathematical community settled on the idea of formal systems. Apparently now Physicist Max Tegmark has formed the "mathematical universe hypothesis" which heads back the other way. I was not aware this prior to this discussion.
With regards to your system, in your mind, you are assigning meanings to the various words. Your proofs rely on picturing things in your mind. Once the mental images are removed, you will find that nothing is obvious or has been proven at all.
An A has at most two Bs. (note I have not restricted my A to being C or D or anything)
Theorem: An A with zero Bs contains at least one E or extends to F.
Theorem: An A with one B has at least one E.
Theorem: An A with two Bs is G.
If your system was a system then anything for which the axioms held, the theorems would also hold. So let A = boy and B = eye. Then your postulate is that "a boy has at most two eyes". None of your theorems follow. You might find specific choices for the remaining letters that are true, but as theorems they do not follow.
