Hello everyone,
I am studying telecommunication electronics and i can't seem to understand how frequency synthesizers and mixers are used. I can understand how they work separately, but can't see how they could fit in a RX system. The synthesizer is used in the PLL of the RX in order to "jump" between frequencies and lock at different channels, right? The mixer also provides different frequencies based on the LO and the received signal, so by manipulation the dc voltage of the VCO we could still get a number of different channels. That is what confuses me. Are they used in the same system? For example, does a GSM receiver use both of them, and if so how?
Also, how do the concepts of up/down conversion apply to those? Why do we use a mixer to up/down-convert and not a synthesizer?
Lastly, why do we perform down/up conversion? Is it to adjust the frequency in order to work with our low-end electronics?
I know these are a lot of questions, but i hope someone could clarify these concepts to me.
Thank you for your time!
