difference between these graphs
s3b4k
Joined Feb 15, 2010
38
does anyone know whats the difference between these two and what is this alteration, like the first 1000 samples are the same but the rest is diffrent and what should i do to make these two look very similar to each other, i applied low pass, bandpass, bandreject and high pass and it doesnt change the shape of the signal. Also when i plot in frequency domain the second signal has a much high magnitude then the original
someonesdad
Joined Jul 7, 2009
1,583
Apply the same filter you'd use to make a 1956 Buick look like a 2009 Corvette. :p
Sorry, couldn't help being flippant -- but those signals are distinctly different. What gives you the idea that one can be (easily) converted into the other via filtering? If this is a homework assignment, you should fully state the problem.
s3b4k
Joined Feb 15, 2010
38
okay i subtracted the two graphs and they look the same except one is shifted 1000 samples, does anyone know how i can shift the graph to the left 1000 samples in matlab. should i convolve it with a delta function? here is a picture third one is the two top graphs subtracted each other.
edit i managed to shift the signal to the left using a for loop, now 1000 samples at the end are gone how do i get those
