Difference between resonance and cutoff and corner frequency of a filter
mishra87
Joined Jan 17, 2016
1,063
Hi all,
Could anybody explain me a bit about resonance and cutoff frquency.
Is there any difference in formulas.
How to calculate these frequency.
Thanks !!!
mishra87
Joined Jan 17, 2016
1,063
They are two different concepts. What has your own efforts to find the answer yielded so far?
I found the same equation to calculate resonant as well as corner frequency !!
1. Resonant frequency -
XL=XC
2. Corner frequency-
-3db point where power to be reduced by half(db/decade)
WBahn
Joined Mar 31, 2012
33,187
XL=XC
Where did you find this same equation for both?
What kind of circuit are we talking about?
Have you tried using the definitions given above to determine those frequencies for that circuit?
Papabravo
Joined Feb 24, 2006
22,111
@mishra87 Do you think it is possible that the same equation can describe the behavior of two or more different circuits?
How many different circuits can you construct with a single lumped C and a single lumped L? I can think of at least four.
What happens in those circuits when we ask: "for what frequency is the capacitative reactance equal to the inductive reactance".
