Not in this case. The D in the suffix is a higher current part, IIRC 600 mA.Sometimes the "D" at the end of the part number means there are back-EMF diodes on the driver outputs.
A look at the data sheet for the STMicro L293D shows prtotection diodes in the output. The data sheet for the TI L293DNE says:Not in this case. The D in the suffix is a higher current part, IIRC 600 mA.
by Jerry Twomey
by Jeff Child
