Difference between CD4511 and 74LS47
Tanur
Joined Feb 14, 2015
3
sorry but i'm only 16 and english is not my native language.
can you please tell me the difference between 4511 and 7447 in a few sentences?
bertus
Joined Apr 5, 2008
23,003
As said the 4511 is CMOS technology that can be used between 5 and 15 Volts and has a latch (buffer) in the decoder chip available.
The 7447 is TTL technology that only can be used on 5 Volts and has only a decoder inside.
For more info look in the attached datasheets.
Tanur
Joined Feb 14, 2015
3
thank you!!!!!
absf
Joined Dec 29, 2010
1,968
As a beginner, you also need to know that 7447 uses a common-anode 7-segment LED while 4511 uses a common-cathode 7-segment LED for display.
Allen
