Difference between 1uF non-polarized and electrolytic capacitor for power supply filter
ischonfeld
Joined Jun 22, 2019
63
I'm using a Micro Power Direct "potted" AC to DC power supply (120VAC to 5VDC). The datasheet calls for two filter capacitors, and 220uF electrolytic capacitor and a 1.0uF ceramic non-polarized capacitor. I don't happen to have any 1uF ceramic caps but do have a 1uF electrolytic cap. Can I substitute it or is there a filtering difference between the 2? Thank you.
38,807
Yes.
They ceramic has a lower ESR and inductance, so it is added in parallel with the electrolytic to better filter high frequency noise.
Stick with the ceramic.
Pyrex
Joined Feb 16, 2022
548
If the datasheet calls to use 1 uF ceramic capacitor, use the ceramic capacitor, not electrolytic. Or try to use a MKT/MKP capacitor. Electrolytic capacitors of small value do have very high ESR compared to ceramic capacitor, so not suitable for filtering
