Detect analog pulse using NE558
chubbspet
Joined Jul 26, 2018
17
Hey guys.
I am trying to turn a short pulse into a logic high for +/- 3 ms (see file/drawing attached). I got this working with a 555 timer, pretty much a clap-on circuit. The problem is I need to detect 3 different pulses, separately and I am having problems using 3 x 555 timers from the same power supply. The threshold I need is so sensitive that I get some false triggers from leak or something. So I have been looking at the NE558 which is a quad timer, but I cant seem to get any good info online on how the pin configuration works and how I would set the threshold.
http://www.mantech.co.za/ProductInfo.aspx?Item=35M1317
Has anyone maybe used this IC that can give me some pointers?
Thanks in advance.
chubbspet
Joined Jul 26, 2018
17
ericgibbs
Joined Jan 29, 2010
21,562
hi,
On your built circuit, did you have any decoupling capacitors on the power lines.?
E
RSA PE.
EDIT:
Have you seen these two 558 App PDF's
chubbspet
Joined Jul 26, 2018
17
Thanks EG
I have tried the de coupling caps, but I am hobbiest and I might have done it wrong. Thanks for the pdf, the data sheet I found on the 558 is terrible..., will go through that first one and post my findings. Thanks again.
danadak
Joined Mar 10, 2018
4,057
For future reference this could be done with a single chip, something
like this. In fact its almost a code-less design, requires one line of code to
start the comparator. I used PSOC 5LP (got lazy), should be able to imp-
lement in PSOC 4 low end part.
I set the trigger at .256V, could be anything you want using a R divider
external or internal DAC.
Regards, Dana.
chubbspet
Joined Jul 26, 2018
17
Thanks Danadak, but I don't have PSOC and I need to do this using a standalone chip. It is outside the scope of the original question.
ericgibbs
Joined Jan 29, 2010
21,562
hi,
Looking at your initial drawing, it shows the input pulses at different amplitudes.
What are the amplitudes and period of these pulses.?
E.
danadak
Joined Mar 10, 2018
4,057
I understand. Note the PSOC is a standalone one chip solution for the
entire problem, all 3 channels. Or 16 if thats needed. Also does not need
a bunch of external timing passives.And accuracy of timing pulse generated
much better than 555. And trigger threshold not sloppy, eg. derived from
Vdd, unless thats what you prefer.
Consider for future designs :)
Regards, Dana.
chubbspet
Joined Jul 26, 2018
17
hi,
E.
Eric, I will send a screenshot of my scope as soon as I get home, but the amplitude is "irrelevant" as I only need to catch the very first part of the wave form and ignore the tail-end, meaning I just need to know when the pulse started. What I can say is that it is a very short pulse, +/- 1ms before it completely dies out. I will try to make a more complete drawing...
ericgibbs
Joined Jan 29, 2010
21,562
hi,
OK, so at some level just above zero volts you want to generate a pulse.
If you want to use IC's, the LM393 is a good low cost dual comparator.
E
