Desperate for help - Verilog
Abin
Joined May 31, 2012
5
Hello.
I am currently working on a published IEEE paper. Nothing fancy, I just want to replicate the result. I am having trouble even with that.
The paper is a Modified Montgomery Modular Multiplier. I follow the algorithm step by step clearly, but no matter what I am unable to achieve the desired result. What am I doing wrong?
Unfortunately, I am not able to find any ( or much ) literary work on this that could guide me. I plead you to go through and give me any advice possible. Thank you!
PS: The code is the Algorithm 4 found in the paper.
Abinand.N
JWHassler
Joined Sep 25, 2013
308
This looks to be a process that finishes in 7 clocks ( 'i' in range [0:6]), but there are no non-blocking assignments in the code.
How do you know the result is wrong? A little more context for your question might help, as would maybe a different forum (say, here)
I have not much else to offer, you, though.
33,277
It would be helpful if you were to format your code reasonably instead of having everything crammed against the left margin.
