Designing multistage signal phasing.
E.E.
Joined Apr 2, 2008
8
Hey guys! Just a little backround, I am a student of E.E. working on some projects for my own learning experience. So I am building a circuit called a phasor for a guitarist buddy of mine. The idea is I have a buffer OP Amp(OP07 for low noise) that has its neg. feedback loop connected to 4 Dual OP Amps(8 stages in total). So my question is what kind of timing I should use. I need the signal to be 90 degrees out of phase. With the original signal passing through the buffer, would it be better to use a 555 timer to delay the signal or a 12 bit counter with an alternating reset voltage. Or any other ideas?
Wendy
Joined Mar 24, 2008
23,857
There is something called a bucket brigade that will delay a signal, but I don't remember much more than that. Both the alternatives you mention are digital, I don't see how they can work. Do you need 90 degrees across the specturm, or just for one frequency?
E.E.
Joined Apr 2, 2008
8
Crap, thats right it is digital. Yes the full spectrum 90 degree shift. Thanks for your input man!:)
Wendy
Joined Mar 24, 2008
23,857
I'm probably inserting foot at this point, but a 90 degree phase shift would be a different delay for each frequency. I'm not sure how you would accomplish that.
An RC circuit would do it, but it is also a filter, which sounds pretty undesirable from here. There might be a way to equalize the signal after the shift though.
The bucket brigade shifts (delays) an audio signal by a fixed number of milliseconds, which isn't quite it either.
There is probably a way to do it, but I'm not the one to know how.
E.E.
Joined Apr 2, 2008
8
Hm, well I was thinking about this. I'm wondering if I can use a digital counter as a trigger instead of running the audio signal through it. So I would have a trigger voltage for each OP Amp, if you understand what I am saying.
The shift does not have to be 90 degrees at all times, just no more than that. I guess I should of clarified.
Hm, the RC would work, but I do agree with the filter.
Ron H
Joined Apr 14, 2005
7,063
I think you need a Hilbert Transformer (Google). Unless you happen to stumble across someone with experience, I think you will have a tough time. I believe digital implementations (but not the ones you suggested) are simpler than analog.
E.E.
Joined Apr 2, 2008
8
Check out this page:
http://www.geofex.com/
There's a phaser schematic, 2nd link down.
(Dang, 2nd time today I've referenced that link) ;)
I've actually referenced that circuit, but I cannot see how it works actually. The thing is, I want to trigger each of the OP Amps(like at the bottom of the schematic) with a slight(nano sec) delay so the signal is out of phase if you understand what I am saying. Thanks though.:)
E.E.
Joined Apr 2, 2008
8
Digital is not an issue for me actually. I just want to avoid D/A and A/D conversions for such a small circuit.
SgtWookie
Joined Jul 17, 2007
22,230
Actually, you could do the whole thing in an MPU; there are scads of them around with multichannel ADCs and DACs built right in.
Your problem then would be reduced to what to do with all the leftover machine cycles. ;)
E.E.
Joined Apr 2, 2008
8
I'm sorry, like I said I am a student so what is an MPU?
