Designing Modular Multilevel Converter
Ajeeth93
Joined Jul 6, 2021
8
Hi!
I am designing Modular Multi Level Inverter in LTSpice using MOSFETs using Near Level Control PWM technique.
I have attached the LTSpice file in this thread.
I do not understand why my model does not give me the desired output voltage value.
Could you please have a look at it?
Papabravo
Joined Feb 24, 2006
22,111
The simulation runs but all the voltages ate negative with respect to node 0 in the simulation.
What is the desired output voltage?
Where do you expect that voltage to be?
Ajeeth93
Joined Jul 6, 2021
8
Hi!
I gave a Sinusoidal reference value V(Sine) of 90 V to a 100 V dc supply inverter. It tries to follow the reference. However the magnitude of output voltage V(n019) is very small. I would like to get an output value equal to the Reference value.
Papabravo
Joined Feb 24, 2006
22,111
Yes I got the same result. Why are all your voltages negative. You would expect some positive voltages but as you go up the tree they get flatter, but never positive. Why is that?
Ajeeth93
Joined Jul 6, 2021
8
Yes I got the same result. Why are all your voltages negative. You would expect some positive voltages but at you go up the tree they get flatter, but never positive. Why is that?
I think it is because most of the supply voltage is dropped across Sub-Module-1. That is exactly my problem. Ideally the Voltage must be distributed even across all the Sub-Modules.
Papabravo
Joined Feb 24, 2006
22,111
I think there might be a flaw in that approach, but I can't see a way to make that arrangement work.
