Hello people,
I am asked to design a multistage amplifier which should have a gain of 100. i.e if i provide 10mV, it should amplify it to 1V.
And i am supposed to add 8ohm Speaker as a Load Resistor.
I am bound to use simple transistors, resistors and capacitors. The instructor only mentioned that i will have to use 2 common emmitter stages following a darlington pair to obtain such amount of amplification.
I don't have any idea about what values should i take for resistors and the capacitors separating multi stages.
Kindly anyone guide me with the calculations required to find out the values.
Thank You.
Thank You.
