Designing a vacuum cleaner based on IoT with burglar alarm.
abdullah8391
Joined Sep 6, 2015
103
Hi everyone, for FYP I have proposed to make a vacuum cleaner based on IoT with burglar alarm.
https://www.daraz.pk/portable-car-vacuum-cleaner-blue-deals-mpg57375.html
I have decided to use vacuum cleaner in above link (Since our instructor said that we don't need it for heavy cleaning, rather we need it for demonstration).
Now my idea is that we design a movable chassis and a camera (night vision) on its top. The chassis motion will be controlled using Arduino. We will connect Arduino with internet (on internet with specific domain or server) using WiFi shield. On the other end we will design an android app on which we will receive video from chassis. This android app will also provide control for chassis (i.e I will control chassis movement through app). Apart from that I want the camera to detect any activity in room when set on burglar alarm mode and let the user know on app. Third thing I want is to also make the robot obstacle detecting (to stop when an obstacle appears) so that it might not hit other things by mistake. So what I need to know is:
1. Is it practically possible to control Arduino using android app as mentioned above?(I personally beleive it is, but want to know any problems that I might face)
2. Which camera should I use?
3. Which Arduino should I use so it can perform all these works?
wayneh
Joined Sep 9, 2010
18,181
The problem you'll need to design around is latency and intermittent signal loss. So you can control a device over IoT, but not in real time with precise timing. Picture operating a rover on Mars. As long as your programming can act on its own with only intermittent control changes, this is fine. For instance I can control my
thermostat with my iPhone. That only requires interacting with the thermostat a few times a day. I'm not driving a car.
