Designing a satellite power system
JulianTech5
Joined Jul 5, 2018
9
I am currently developing a concept picosatellite project launched by a pocketqube that is in a very early development phase, to be completely honest I have very basic electrical engineering experience when it comes to power systems and want to make sure what i'm doing this fine, the processing and communications part of the satellite are already sorted out and I just need help regarding power management. I am currently designing the power management for 2 separate devices, a small 26x26mm board satellite and a larger pocketqube. More or less to have an idea of the sort of power needs we are talking about here, the board satellite will only consume about 60mw at max and the pocketqube will probably consume about 170mw at most. The smaller board satellite will have no batteries and will use passive attitude control to point at the sun, while the pocketqube will have a small Li-ion battery and will most likely have active attitude control.
I have currently decided to use the SPV1040 MPPT integrated regulator for charging the battery, this will then be combined with some sort of off the shelf overcharge/overdischarge protection circuit. I am hoping to use a TPS62120DCNR switching regulator to regulate the power directly coming from the batteries in the pocketqube and the solar cells in the board sats. The current prototype uses a linear voltage regulator but I would like to increase the efficiency of the regulator.
There is quite a bit of stuff to take in mind and this is sort of an open discussion, feel free to ask me anything about the project and any input and collaboration are really appreciated since I'm working on this on my own.
Thank you for taking your time to read this post,
Julian
dl324
Joined Mar 30, 2015
18,275
Welcome to AAC!
Thank you for organizing your thoughts in paragraphs. A few extra blank lines would have been appreciated.
  1. What are the solar panel ratings?
  2. What are the battery specs?
  3. What is your assumption for hours of daylight?
  4. How long does the device need to operate in total darkness?
  5. What environmental control do you have?
  6. What voltage does the regulator need to provide?
  7. What is the spacing between the two boards? Is it just one satellite with 2 boards? You mentioned "board sats, so it's unclear.
JulianTech5
Joined Jul 5, 2018
9
Welcome to AAC!
1. Voltage (Open Circuit) 2.62V Voltage (Max Power)2.33V Current (Max Power)14.6mA Power (Max Power)34 mW Efficiency 28%
2. it completely depends on the beta angle of the orbit and other parameters but for example a standard LEO orbit would have just above 45m of daylight out of a 90m orbit.
3. Approximately 30-45m, same as last question
4. None, basic insulation on the pocketqube and just a bare board on the board satellites. (Seems risky and not appropriate for a Li-ion but batteries have been tests in nearly exact situations on previous missions)
6. 3.3v
7. It is a mothership pocketqube launching smaller board based satellites, sorry for my bad explanation.
Im more than happy to explain anything from this project, thanks for your reply
dl324
Joined Mar 30, 2015
18,275
The smaller satellites have no power source? Are they tethered to the larger satellite? How do they get their power? How long do they need to operate?
Does passive attitude control mean none?
You didn't give battery specs. Charging Li-ion batteries is not recommended below freezing or above around 120F. What are the temperature extremes you expect?
be80be
Joined Jul 5, 2008
2,394
There $25,000 us dollars and you want make one the links was for the full deal.
You have to launch it too.
dl324 it going to be cold and it I'm sure it will get a little hot coming back.
But they most power from the sun I think most use supper cap's to hold the power while in dark.
JulianTech5
Joined Jul 5, 2018
9
The smaller board satellites will have 2 trisolx triple junction GaAs solar cells, of the same spec as the pocketqube. These will only operate while in sunlight. Passive attitude control means that the craft will be stabilized using magnets with earths magnetic field, active attitude control gives you the ability to point the craft in any direction on command.
I don't have exact battery specs yet but a common 1 cell 3.7v lithium ion battery of under 1000mah will be used. Temperatures expected are around -30 to 80c thought it will mostly hover around the -15 to 20c mark.
50$sat (a previous pocketqube satellite) used a very similar system with a small camera Li-ion battery.
JulianTech5
Joined Jul 5, 2018
9
I have found a provider that launches them for 16k, as I said before this is a very early development stage and launching it is purely hypothetical.
Super caps could be an option to hold power during shade.
be80be
Joined Jul 5, 2008
2,394
Back years ago I seen where they used Li-ion battery it put in a case and used resistor to keep it warm so it could charge these was launched from high altitude balloon.
JulianTech5
Joined Jul 5, 2018
9
Indeed some satellites use nichrome wire and other heaters to maximize the charging and output of the batteries however people have successfully avoided this before.
be80be
Joined Jul 5, 2008
2,394
They had to heat it some how because you cant change the fact that 1000 mA li-ion battery will only put out 500 mA at 18C
and it drops fast from there the colder you get you'd be lucky to get 100mA -15 and like above 500 at 20C
JulianTech5
Joined Jul 5, 2018
9
indeed, tests will obviously have to be carried out, but so far it looks like it still falls under the required power constraints.
JulianTech5
Joined Jul 5, 2018
9
Does anyone have experience with switching regulator circuit design and using the SPV1040? I'm pretty set on those devices and just want to make sure im designing the circuit well.
JulianTech5
Joined Jul 5, 2018
9
Tethering might be needed though due to regulations with launching such small satellites, but for now lets just say its not tethered.
