Designing 3 24v analog input to single output
patelankur2603
Joined Jun 6, 2022
40
How much current do you need out of the 24 V output?
What power source is available to power this output circuit?
ak
i have not yet calculated the exact value but around 420 mA of current would be fine. i will be powering it through external regulator which is 24v/2.5A O/P
patelankur2603
Joined Jun 6, 2022
40
For that you want a higher current diode for the circuit I posted, such as a 1N400x (x = 1 through 6) or a Schottky diode such as the 1N5818 (which has a slightly lower forward voltage drop).
Thanks... i replaced it with schottky diode. I am still not sure it will work or not ... will test this thing and let you guys know.
AnalogKid
Joined Aug 1, 2013
12,266
It still is not clear to me if there is a single, common GND for all input signals, output signal, and power. Because of this, here's my suggestion.
Three optocouplers, one for each input. The three output transistors in parallel drive a PNP power transistor (or power darlington) as the output switch. LEDs in series with each opto output will give an indication of which one is on. Schematic later, unless someone else wants to whip up one..
ak
BobTPH
Joined Jun 5, 2013
11,643
ak
Exactly what I was getting at many posts ago. I asked if the inputs and outputs had a common or were isolated, and TS answered that is neither. I don’t think he understands what a common ground is, or what is meant by isolation.
He now says all the outputs come from a single chip, which implies they have a common ground.
We need to determine if this s true and if the output also shares a commonground before we can give a solution.
TS, if you understand what I am talking about, please inform us about the grounds. If not, tell us what you don’t understand.
AnalogKid
Joined Aug 1, 2013
12,266
Only if the three "sensors" make up only one electronic assembly. If they are three separate assemblies with independent power sources, then who knows.
The 2803 has 8 NPN open-collector darlington transistors with all of the emitters tied together. If this really is the output stage of a sensor module/assembly/whatever, then the output goes high by being pulled up when a transistor is turned off. This now raises the question of how much current is available to drive something like an optocoupler input.
OR
The sensor output is one stage of a 2803 that goes low on "sense". In the state where the TS says the output is 0 V, the actual case is that both output pins are at 24 V; one direct connect and one pull up resistor to a turned-off 2803 section.
I was gonna do a schematic, but now I'm holding off; still too many questions.
ak
patelankur2603
Joined Jun 6, 2022
40
Yes, they will have common ground.
patelankur2603
Joined Jun 6, 2022
40
OR
ak
the wires should handle 0 to 24v , because inputs gonna give 24v supply when system activates and i need it to pass to output which is a spray module of 10 watts, 24vdc which in fact activates spray (water)
patelankur2603
Joined Jun 6, 2022
40
OR
ak
i output current from each channel of 2803A is around 30 to 300 mA. but after that there are many resistors and diodes so there will be drop in the value. I am not worried about the drive current right now. I am trying to build a schematic of what components to use and how to workout the logic. Later on while testing, we can change accordingly.
AnalogKid
Joined Aug 1, 2013
12,266
What is the value of the unmarked zener diode?
What is the current rating of the unmarked p-channel MOSFET?
What is the cold value of the PTC?
Can the 24 V source in this schematic supply the current you need to power the spray module, or does the power for the spray module come from a different voltage source?
ak
patelankur2603
Joined Jun 6, 2022
40
ak
its a power mosfet, IRFR9024NTRPBF . please check the datasheet attached for mosfet. PTC cold value is 0.5 ohm. 24v supplies the current i need to power the spray module. no external source is connected seperatley to spray circuit.
