design encoder
rainyleow
Joined Apr 3, 2008
2
may i know how to design 8-bits encoder that link to 7-segment decoder or PIC (need to show the output)?
how is the circuit or the model look like?
THANKS
21,225
I think you could use a ROM with 8 address inputs and 14 outputs, seven for each digit.
Or you could write the boolean equations for each of th eseven segments of each digit and implement it in n FPGA
Or you could read the 8-bits with a microcontroller and time multiplex the seven segment outputs.
OR...
and so forth
