Design a sequential machine that implements a door lock control.
HUSSEIN123
Joined Jun 1, 2021
Design a sequential machine that implements a door lock control. The input is a
sequence of digits where every digit is between 0 and 3 inclusive. The door will not open unless
the entered number sequence is 102103.
The input entered is from left to right. First 1 then 0 then 2 then 1 then 0 then 3 => open the
door.
Implement the machine using Moor Model. Use D flip flops. Show all steps of design from
state diagram till block diagram.
PLEASE WHO CAN HELP SOLVING THIS??
35,246
Sounds like homework. Thread moved to Homework Help.
Start by showing us what you have designed so far.
Welcome to AAC!
Fatima345
Joined Jun 5, 2021
door.
Did you find the solution?
Deleted member 115935
Joined Dec 31, 1969
state transitions look good,
A clue, what causes them to move from one state to the next, and what would cause them to stay in the current state ?
