Sequential circuit design help please!
crb123
Joined May 16, 2017
8
Currently studying 1st yr electronic engineering....and have a question ...any help will be much appreciated...thank you.
ok...so have to use two switch. and whichever flipflops .....
switch1 has two state on/off.
switch2 is a momentary push switch.
light on sequence is
IF
(switch1=ON), then press n release switch2, then (switch1=Off), then press n release switch2.... light ON
ELSE light off
Kermit2
Joined Feb 5, 2010
4,159
Google a SR flip flop.
One switch will be an input, another switch will serve as a clock to move the input to the latch side of the flip flop.
crb123
Joined May 16, 2017
8
thank you for your reply....but if possible please cralify....hopefully with circuit diagram......
how can you input a sequence of 4 steps in one SR FF.........please note the 4 step sequence is (move switch1 to ON), ; then press n release switch2, ; then (move switch1 to Off), ; then press n release switch2 again.
WBahn
Joined Mar 31, 2012
33,122
You really need to at least take a shot at solving your own homework first. Then members can provide feedback and help guide you along. Just use your best understanding of how you might try to approach this -- it doesn't have to be right, but we need a starting point.
crb123
Joined May 16, 2017
8
I would approach it as above state diagram ifff both the inputs were normal on/off switch...say switch A and B....and required sequence was A.b.!A.b
...but don't know how to tackle momentary switch...
EM Fields
Joined Jun 8, 2016
578
A SPST Normally Open (Form A) momentary push switch connects its switch contacts when its actuator is pushed and disconnects them automatically when the actuator is released.
WBahn
Joined Mar 31, 2012
33,122
So now walk through it and make up a timing diagram that covers all the possible scenarios and see if it behaves like you want it to. If it doesn't, focus on understanding what is preventing it from doing so.
