Deriving a state table for a finite state machine
dinkofelic23
Joined Nov 28, 2020
43
I see it!
got the column 11 och 10 of b,a wrong!
Sweet, otherwise all correct I guess, thank you very much! Now I shall try to make the circuit work on a breadboard :)
dinkofelic23
Joined Nov 28, 2020
43
Another question about the K-map, if the state 11 is regarded as a forbidden state, can I then put don't care conditions on the row 11 of q1q0? Like this:
The functions gets minimized quite a bit then. I am using D Flip Flops btw.
Analog Ground
Joined Apr 24, 2019
460
I guess my question is what do you mean by "forbidden state"? Perhaps you can change your state diagram to show what is meant? My suggestion would be to always go back to the state diagram when making changes. Then, go forward again. I think making changes at the K-map stage is not clear and error prone.
There are ways to perform state minimization which can save logic but that is a relatively complicated step. The other thing is to look for common minterms between the k-maps. I don't see any.
I would be interested in your "forbidden state" step. Maybe I can learn something!
dinkofelic23
Joined Nov 28, 2020
43
I guess I have already done the don't care conditions when assigning the next state, for example input a could be ba or !ba. But I thought if it is a rule of thumb to simply put don't care on the state 11 since that one is not obtainable with a D Flip Flop since the input is inverted and can only become 10 or 01 with one input D. But I am not sure about this...
dinkofelic23
Joined Nov 28, 2020
43
This is what I got, what do you think? The muxes are a 8 to 1 mux on the breadboard but Logisim seems to not allow 3 select inputs so I split it into multiple 2 to 1 muxes.
Analog Ground
Joined Apr 24, 2019
460
I cannot understand this schematic. Can you do it just with standard sum-of-products form. AND and OR gates and put on some net labels? Why muxes?
