The idea is to base the ampere on quantum metrology instead of a force measurement. Volts using "Josephson junctions", Ohms using the "Quantum-Hall" effect and current with a single-electron current standard (charge on a electron).I seem to recall that the ampere was (or perhaps is going to be) replaced by the volt because we can produce a voltage with an extremely high degree of accuracy and precision using Josephson junctions in the presence of a specific microwave radiation, which would give it a resolution comparable to the definition we already have for length and time.
https://www.euramet.org/fileadmin/d...011/SI_JRPs/SIB07_Publishable_JRP_Summary.pdf
