Fellow AAC folks,
I'm looking for an idea how to demux a square signal to two output without using a demux IC.
Input1: a 5V high or low Z (I can opamp it if needed), square signal, variable frequency (10Hz to 1kHz).
Input2: a 3V3 high Z GPIO (which is the selector for output 1 or output 2).
I was thinking to use a transistor to pull the signal down. I could use an opamp to reverse Input2 and so it pulls down on one output or on the other one.
Anyone got a better idea? (I have no logic ICs, that would be easy to solve with some gates).
