demultiplexer
38,858
"Doesn't work" tells us little about the problem.
Is this strictly a simulation?
Can you be more specific about how it's not working?
38,858
You appear to be having convergence problems, which can come and go with just a slight change in the circuit.
Try the simulation with the .uic Spice command to "use initial conditions" which skips the initial DC operating point solution, and often solves the problem.
Do you know how to enter Spice commands in your simulator?
28,415
The circuit is OK, but not a very efficient use of components. It can only flash one color at a time, you could do that with a single pole 4 position switch.
DickCappels
Joined Aug 21, 2008
10,661
Did you remember to put a logic low on the Not-G pin (Enable pin), pin 1 on the package I am looking at?
CMOS inputs left floating in real life produce unpredictable results.
