Delay generator
38,736
Carl can you do a temperature run on that circuit and post the result.
Below, which shows about a 0.4µs change from 25°C to 75°C, but I have doubt that the model shows an accurate change in the Schmitt-trigger threshold with temperature, which is the main change that would affect the timing.
Certainly if you are concerned about the delay change with temperature, a comparator version of the circuit would likely be more stable.
ericgibbs
Joined Jan 29, 2010
21,552
hi Carl,
Many thanks for the test.
I must say many years ago when using CMOS Schmitt Gate timers, in wide temperature mobile environments, timing drift could sometimes be a problem.
Eric
AnalogKid
Joined Aug 1, 2013
12,254
Agree. In many applications, the only advantages of a 555 over other methods are the temperature stability of its two transitions levels, and that extra-beefy output stage. While it was the 555 that prompted my tagline, I do use them sometimes.
ak
