Defective SMD Cap. How to find replacement without partlist or schematics.
panic mode
Joined Oct 10, 2011
5,226
Clean it, take pictures of both sides along with making of key components... you may not have actual schematics but datasheets could provide vital clues.
ronsimpson
Joined Oct 7, 2019
4,804
We need the information on the two film caps. Voltage and capacitance and part number.
Can you tell if the ceramic capacitors are parallel with the film caps. Probably are. (ohm meter test)
k.banks
Joined Oct 2, 2024
9
Thanks for all your feedback. I Will have a check tomorrow and clean the board and upload new pictures and all info i can find about the two film caps.
35,136
Are C129 and C130 in parallel?
If so, then one 100nF and one 10μF.
What were the colours of the bad capacitors, if possible to see?
