Debugging an openSource drawdio circuit (TLC555 Based project)
AlbertHall
Joined Jun 4, 2014
12,637
Having slept on the problem, there is a better way to get best volume on a 3V supply. Don't try this on a 9V supply as the current through the transistor will be too great.
RichardO
Joined May 4, 2013
2,270
I don't like the 10 ohm resistor. This is how I would do it. Note that this drive circuit works best at higher power supply voltages. It works very poorly at 3 volts.AAC_555_spkr.png
