Debounce Switch Circuit - Choosing Component Values
dmarciano84
Joined Oct 1, 2023
36
I am working on a project with a PIC16F18877 which will have 5-6 buttons as input (which will be read as interrupts) and I need a debounce circuit. I came across the following circuit on Microchip's website which I should have all the components to make it:
However, they provided no guidance on the best way to should the values for R1, R2, and C1. As this is the first debouncing circuit I have ever had to design/use, I would appreciate any guidance on the best way to choose these values (or at least a starting point). TIA.
AnalogKid
Joined Aug 1, 2013
12,282
It is with sadness that I agree. A debounce circuit is basically a timer, and I have it on good authority that a PIC can time things.
Interesting take on the classic - U1 changes state at the *end* of the debounce period.
ak
Ian0
Joined Aug 7, 2020
13,291
Might also be able to debounce through programmed delays.
Yes - just don't read the switch inputs too often.
If the repetition period of the program loop that reads the switches is longer than the bounce time, you don't need any circuitry at all.
dmarciano84
Joined Oct 1, 2023
36
A link would be helpful in giving some context.
Are you going to trigger something on switch closure and switch opening? Or just one or the other?
My mistake...it was actually from Digikeys website. Here is their article are various debouncing strategies: https://www.digikey.ee/en/articles/how-to-implement-hardware-debounce-for-switches-and-relays
The program won't be reading the switches via a loop. It will be using interrupts on either the rising and/or falling edge (having fully decided yet).
Thank you...I will give that a try and see how it goes. Thanks for a suggested starting point.
dl324
Joined Mar 30, 2015
18,478
I've never had issues with using switches that weren't debounced for interrupts.
If you're triggering on both edges, you should keep the extra diode and resistor (that wouldn't be required if you triggered on one edge or the other). Since switch bounce can vary from a couple ms to up to 20 (for military applications), I'd start with a 5ms RC time constant (47k and 0.1uF). Can't give more specific values without knowing the switch type and which edge you're triggering on.
eetech00
Joined Jun 8, 2013
4,733
Hi
See simulations below. I've shown them using a CD40106B but a 74HC14 could be used as well for a 5v circuit.
The switch bounce duration is stepped using 50ms, 100ms and 150ms.
Here is a simulation (#1) of the circuit with the RC values shown in post #2.
You can see the the output of the inverter bouncing (a bad thing).
Now, here is the simulation (#2) with recommended RC values:
You can see that there is a clean, bounce free, output from the inverter, even at 150ms of bounce duration.
I don't know who your project is for but I would go with the values in simulation #2 unless you are certain of the quality of the switch(s) you'll be using. High quality switches usually have bounce times around 20ms but I'd plan for 50-100ms bounce times.
Reference:
http://www.ganssle.com/debouncing-pt2.htm
Ian0
Joined Aug 7, 2020
13,291
Unless your interrupt routine takes longer to run that the bounce time, then you will need a debounce.
I would use R2=10.R1 and no diode - that would make it almost symmetric.
dmarciano84
Joined Oct 1, 2023
36
The switches I am currently planning on using are PTS645SL50-2 LFS and almost definitely going to be triggering on the rising edge.
Potentially it may be extremely close/slightly longer as the buttons will be updating an LCD screen. I literally just got the screen working a few minutes ago so, but I haven't planned out all the screens yet so I don't know yet which screen will take the longest to print. My thought was to maybe set some bit flag to determine which screen should print and then just set that flag in the ISR and do the actual updating from the loop I am currently in so that way the code isn't staying long in the ISR. My concern though was timing; that is, ensuring the screen is updated before the next ISR can be handled/trigger. But this is something I am still designing/testing. Because of some of the opens questions/design choices, I figured it was safer to just plan to debounce the switches rather than do a design without one and then find out under some circumstances I need them and have to do a redesign.
