DickCappels
- Joined Aug 21, 2008
- 10,187
Your output stage is more than adequate to drive and inductive load at 600 ma (the design max is 6 A). If it turns out that the inductance is too high for 60 Hz operation there are some tricks we can try to speed it up.
Though Alec_t's observation that the chip is designed to operate down to 100 Hz is correct, if you are not going to be in high volume production and if an occasional controller comes by that needs some special attention to get it to operate down to 10 Hz, I think it is safe to go ahead and drop the minimum oscillator frequency down to 10 Hz. In the K8004 the formula for C3, the timing capacitor is C3 =1/10 Hz x0.7 x 200,000 ohms, For 10 Hz use a 0.68 uf film capacitor.
To limit the maximum frequency to about 70 Hz (for margin) change R3 to 27k.
Is there anything besides output driver and oscillator frequency to which you think needs attention?
