DC to DC converter question
noweare
Joined Jun 30, 2017
115
I am building a battery pack using lithium-ion batteries salvaged from laptop batteries.
I have to boost the nominal 3.7 to 5 volts. The battery voltage will vary from 4.2 to 3.0 volts
I purchased a boost converter from banggood but the output voltage varies if the input
voltage changes even a little bit. I thought converters regulate the output over a range of
input voltages. Is this not the case ?
noweare
Joined Jun 30, 2017
115
It's bangood so the spec are pretty thin.
Description:
DC Boost Converter 2A Power Supply Module 2V-24V To 5V-28V Adjustable Regulator Board
Item Name: DC Boost Converter
Max Output Current: 2A (Recommended for use in 1A)
Input Voltage: 2-24V
Max Output Voltage: 28V (Recommended for use in 26V)
Efficiency: > 93%
Dimension: 30x17mmx14mm
Features:
Smallest volume Adjustable DC boost converter in the market,can be easily installed in small devices.
Use MicroUSB input,with the USB charger or mobile power through the phone data cable can easily get 9V, 12V, 15V, 18V, 24V common voltage.
Very convenient to use.
Ultra wide input and output voltage, high conversion efficiency.
Note:
The output voltage should be greater than the input voltage.
Peak output current should not exceed 2A.
Package Included:
1x DC Boost Converter
danadak
Joined Mar 10, 2018
4,057
There may be a minimum load required for the output to stay
in regulation. If it has been left out of datasheet put a load on
it, say 50 mA or so, to see if it starts regulating.
Regards, Dana.
noweare
Joined Jun 30, 2017
115
Hello Dana,
I had a 20 Ohm load on the output but it seems there is no regulation going on.
Thanks for your reply.
noweare
Joined Jun 30, 2017
115
Yes I have, there is a multi-turn pot on the board to adjust output voltage. It is more like a fine
adjustment though.
noweare
Joined Jun 30, 2017
115
The potentiometer is a "fine" adjustment. For a set input voltage the output can be adjusted maybe + 1 volt above the input voltage. You can get the output from 5 - 28v but the input would have to be close to the output. That's what I meant by fine.
38,741
So you mean you can't adjust it for a 28V output with a 5V input?
If it can only be adjusted for 1 volt around the input voltage then I would not call that an "adjustable regulator".
noweare
Joined Jun 30, 2017
115
Yes, that's correct. I can't get near 28v with a 5 volt input.
I have a 20 volt power supply that can deliver 1.5 amps that I am using to drive the board.
I have a 20 load on the output.
I can only apply 4.5 volts to the input before the input is drawing 1.5 amps.
The output voltage is 6.3 volts, so the output current is 6.3 volts /20 ohms.
I got these on banggood but they are also sold on Amazon. Mixed reviews, some people with the same experience I am having.
28,129
Really sounds like a defective unit.
NOTHING in that specification mentioned any sort of regulation. AND, since regulation is a plus, any description of a regulated device would include it. So what you have is a fixed-ratio DC to DC converter. What you need is a regulated converter, which would probably cost a bit more.
Now you can see that if the specification does not say "regulated output", it does not have a regulated output. While you can certainly add a regulator it will reduce the overall efficiency of the system quite a bit, and for a battery powered system that usually matters.
