hi i have this motor pic attached.....if someone can help me and tell me what do i need to use this in my lathe ...i need speed control and reverse
tia
tia
@MaxHeadRoomyou would need to add a reversing relay
I my experience no. The advised direction is the keep the flywheel from coming off, they are threaded onto the shaft. Reverse direction and they come loose. Max may have a different reason though,Could the "Rotation CW" marking on the motor imply any brush arrangement which would make the motor run poorly in reverse?
Typically no, not often done anymore on TM motors, they are uni-directional because of TM application (one-way track) and also the threaded direction of the flywheel.@MaxHeadRoom
I could do that if you wish.would you be able to put one together for me ?
