I'm freaking out over a high pitch noise (very faint) coming from my power supply and wanted to clarify some things so that I can be sure i'm safe.
I have a 12V DC power supply (1A) that has 2 components connected in parallel. The circuit works perfectly but I'm pretty certain that this circuit is trying draw more current than power supply can provide.
What happens in this instance?
- Does the power supply just continue working while limiting current draw to 1A?
- Is there any danger either to the power supply or components in this case?
- Why am I hearing this slight screeching noise? Another thing to note is that shaking the power supply you can hear some sort of small piece inside moving around.
