DC power sockets - how many amps can they take?
MattP
Joined May 21, 2012
54
I'm after a panel-mount power connector for a project. The project draws around 10A, so I'm having trouble finding a power socket type that's rated for this amount of current. As I'm going to be sharing the project online as a how-to guide, the sockets need to be really easy to find, which limits my choice further still.
Here's the closest I've found so far:
http://www.ebay.co.uk/itm/2-Pin-Pan...3?pt=UK_BOI_Electrical_Components_Supplies_ET
The problem is that it's rated for a mere 3A, so isn't technically usable....
So does anyone have any suggestions as to which socket I should look in to getting? I've used RC connectors in the past, but they're unfortunately not able to be panel mounted.
It doesn't have to be specifically a power socket, but just something that can handle the current.
Thanks!
30,809
What voltage are we looking at?
Have you looked at the RV/Trailer type sockets, they usually come in bulkhead type also.
MattP
Joined May 21, 2012
54
Hi Max, the voltage will be 15v.
Just had a look at rv sockets (pollak sockets?), and it seems they're pretty expensive and quite large, so I'm not sure they're suitable.
#12
Run down to the local electricians supply house. They will have the most available and cheapest (per amp) connectors in the neighborhood.
MikeML
5,444
I like Anderson Power Poles. I have so many of them I should have bought stock in the company... Every Ham rig I own, first thing, cutoff the Yaesu, Kenwood, Icom proprietary connector, ditch it, and replace with red/black powerPoles. They can be used as a through-bulkhead, captive connectors. You can assemble them with many contacts, and polarize them so you cannot mix up different cables, if desired.
