DC power jack shows voltage in 3rd pin when plugged in?
geratheg
Joined Jul 11, 2014
107
I have a few DC power jacks of various sizes and shapes with 3 pins, 2 of them are connected when not plugged in, 1 is isolated for positive. When a plug is plugged into the jack usually the 2 that were connected disconnect, one goes to negative, the other - which I will call the third pin - isn't connected to anything. This is true for all power jacks and none of them show voltage in the third pin except for one.
That's strange, where is this voltage coming from to the third pin if the pin is disconnected? Is this something to worry about and should I get a new adapter?
This is a picture of the adapter that shows voltage, I only have one piece: 5.5mm x 2.5mm DC Power Jack
30,691
You would need to show all the connections? if only 2 wire DC is used then what is connected to the other jack connection, if any?
geratheg
Joined Jul 11, 2014
107
Oh I don't know, maybe I should just use it without worry. Third pin isn't going to be connected to any circuit or casing. I really don't know what the third pin is there for? What are some applications of it?
to3metalcan
Joined Jul 20, 2014
263
It's for battery power. You connect the positive battery terminal there. The jack automatically disconnects it when you plug in. If you see voltage there, it's broken, but if you don't have a battery or other power source, it doesn't matter.
geratheg
Joined Jul 11, 2014
107
Thank you for the responses. I don't have any use for it, and no longer need to worry.
As for battery power, it would make more sense to connect the negative terminal of the battery there? Since the third pin is connected to the negative terminal when the power plug is disconnected.
shortbus
Joined Sep 30, 2009
10,049
The jack your talking about is more likely to be an audio jack instead of a power jack.
The pin disconnecting shuts off the devices internal speaker when an earphone is plugged in.
to3metalcan
Joined Jul 20, 2014
263
Hmmm, I doubt it. The form factor might be slightly different, but I'd guess the OP is talking about something like this:
