DC Motor on Robotic Trolley
Lambo Av
Joined Apr 24, 2019
63
Hi, I would like to get some help on this.
Use the correct D.C. motor for this robotic trolley.
Guidelines
1. Carries a maximum total mass of 6Kgs.
2. Goes up a slope of 30° at a linear speed of 40m/min with maximum total mass.
3. Operated by four (4) D.C. motors.
Assuming frictional coefficient of the path and wheel dimension is allowed with justifications.
P.S. total mass = load + cart structure
Explanations must be given to the design safety margin.
You can refer to the Diagram attached
After reading a few sites on the types of DC Motors, I have chosen a shunt DC motor. Am I at the right track?
Lambo Av
Joined Apr 24, 2019
63
MaxHeadRoom
Joined Jul 18, 2013
30,791
Actually to distinguish between PM and shunt, the description should be 'shunt-wound field'
Series wound-field motors include automotive starters and Universal motor (power tools, vacuum motors) etc.
The nature of a series field motor is that it has very high starting torque, but essentially operates in a run away condition when unloaded.
This can also happen to a shunt wound field where the field supply is lost.
Unloaded RPM decided by friction and windage etc.
There is also BLDC motor variety which come under the DC label..
Max.
Bernard
Joined Aug 7, 2008
5,784
" In small DC motors, PM can be used for the stator. "- good advice; also where are you going to find a wound
stator in fractional HP gear head motors ?
Get out your table of conversions as you have meters, kilograms, & minutes & you want watts.
I came out with about 5 W / motor with out allowences for additional loads or maybe about 7.5 W ?
Lambo Av
Joined Apr 24, 2019
63
Meaning, wound stator is out for this situation?
Lambo Av
Joined Apr 24, 2019
63
Max.
Wow, thats a lot of DC motors haha. In your opinion, which one suits best for this situation?
Bernard
Joined Aug 7, 2008
5,784
Is this just a paper project or is there hardware in its future ? As a start might figure what size of a motor is required. The last time I studied things like this it was about 69 years ago - still want to use my figures?
Lambo Av
Joined Apr 24, 2019
63
Its a paper project. Sure, I appreciate your figures.
Lambo Av
Joined Apr 24, 2019
63
Bernard
Joined Aug 7, 2008
5,784
Let us see your work. What is the magic of picking 30 deg. ? What is the sin of 30 deg. ? What is the relationship of work , power, potential energy, & time ?
