Hello Everyone,
I would like to DIY a setup as shown below. Basically, use a 5S 18650 battery with a BMS circuit to drive a DC motor.
Question 1
When I want to charge the battery using the BMS, I don't want the BMS to drive the motor.
So when I connect the charger, the switch should allow me to charge the battery through the BMS and isolate the motor.
Basically, I want to have either a charging or discharge setup. What kind of switch or circuit do I need in this case?
Question 2
Is the BMS circuit with 30 A max too much. Should a 10 A BMS be enough as the circuit draws only 5 A?
Question 3
The on/off switch circuit i need has to be button type. When pressed, it switches on and stays on until pressed again to switch it off.
Thank you everyone for any advice you can provide.
Question 1
Question 2
Question 3
