Previously I asked some questions regarding motor control. Well, I'm actually working on designing one by myself, specifically a motor control for treadmill. The purpose of this post is to update what I have done so you can throw your 2 cents and give suggestions. I attach an schematic of what I have so far. I'm now selecting a proper mosfet and a gate driver. As recommended in a previous post, I plan to use the IXFH80N25X3. Datasheet: https://www.mouser.com/ds/2/205/DS100753B(IXFA-FP-FH-FQ80N25X3)-1113848.pdf I thought of using parallel MOSFETs, but this one seems to stand my ratings so I don't see the need to use two mosfets (so two snubbers ?) and increase project complexity.
And this gate driver sounds good: http://www.ixysic.com/home/pdfs.nsf/www/IXD_609.pdf/$file/IXD_609.pdf
As you can see, I'm now trying to design the power stage. I will use PWM @25 kHz from an STM32 MCU. Also, I will sense motor's current using the LTS 25-NP sensor.
