MaxHeadRoom
- Joined Jul 18, 2013
- 30,814
The last one I put together I used a 8pin micro to control a PWM ramp, the PWM timer ramps up with a resolution of 256 steps.
What exactly do you mean by this? The technical answer is no because a rotary switch works by being physically moved with the hand. Of course you can make a robot that moves the switch lol. All things considered, my circuit is an easy and electronically safe solution due to its simplicity but at this point we need more information because you are kind of all over the map.is there a way to make this rotary switch "digital", so that the voltage automatically selects the right path, without manual input?
The current a simple PM DC motor draws is related to the applied voltage. The power tends to vary as a second order function, since as the speed and torque both increase and the power relates to the product of speed and torque.Yes.
Makes no difference how you control the motor linearly, be it transistors, variable resistors, or other means.
The amount of dissipated power in the controlling device will be the same.
