Hi every one;
I have attached a schematic for a Dc-Dc boost converter ; the left side is working as a window comparator while the right side is the main circuit used to boost the voltage from 12v up to 24v
when I tried the Dc-Dc circuit, it worked very well , but when connect it to the window comparator and increase the voltage slowly the relay switches on-off very fast , I've tried the window comparator without connecting it with the boost circuit and it worked
what is the problem ? shall I use another driver instead of the relay ??
Thanks all
Thanks all
