Datasheet does not provide beta of transistor!!!
babaliaris
Joined Nov 19, 2019
208
I still don't understand one thing. Does b actually depend on the rest of the elements? (Resistors, capacitors, etc?) I'm still confused with that Hef.
In theory exercises, the exercise would always give me b and all the characteristics of the circuit (resistances, capacities, sources, etc) and I just had to find everything else (voltages and currents).
But in this case, I'm still not sure how to do this.
dl324
Joined Mar 30, 2015
18,491
Beta depends on a number of things: temperature, collector current, collector-emitter voltage.
When you're using a transistor in saturation mode, a beta of 20 is used for BC547. For 2N small signal transistors, e.g. 2N3904, 10 is used. For power transistors, it can be lower; unless they're darlingtons. For darlingtons, e.g. TIP120, a beta of 250 is used.
dl324
Joined Mar 30, 2015
18,491
No, but the site where I bought it, it said that it operates from 2 - 3.6 volts and 20mA.
20mA is likely the maximum DC current. That doesn't mean you need to operate it at that current. For an indicator that isn't exposed to bright light, a milliamp or two is usually sufficient.
It's also possible to drive most LEDs at a much higher peak current, for example when multiplexing.
These Kingbright LEDs, have a peak current of over 100mA:
In the notes, it states the conditions for using the peak current.
EDIT: Specs for an old HP LED that had a maximum peak current of 1A:
Papabravo
Joined Feb 24, 2006
22,115
So in other words, you are saying I don't need to know b and the transistor currents?
Not exactly. In most designs you can reduce the effect of β on the final circuit by choosing a voltage divider biasing circuit. The stable DC bias current means the device will perform as an AC amplifier over a wide dynamic range and the actual value is less relevant because you are looking at the small signal gain (hfe) rather than the large signal gain (hFE or β).
MrAl
Joined Jun 17, 2014
13,862
There are a lot of transistor circuits used with LEDs.
The two most common are the:
1. Switch
2. Constant current
When used as a switch, the transistor just has to turn on and off. For this circuit you ensure that the base current is around one-tenth of the collector current. So if you have an LED that takes 20ma in the collector (with current limiting resistor) then you need at least 2ma base current.
If the LED takes 200ma in the collector, then you need 20ma base current.
The Switch circuit is used mostly when there is a constant supply voltage like 5v or 10v.
When the supply voltage can vary widely, like from 5v to 15v, then a constant current circuit is used, and this can also be a Switch too. There are a number of ways that the constant current circuit can be built so it is a good idea to look some up or ask here.
In any of these circuits the circuit is designed such that it does not depend highly on the Beta of the transistor. That is because the Beta can vary widely from device to device and with temperature and with supply voltage.
So it is not that the Beta does not matter, it is that the circuit is designed so that the Beta does not matter as much, but it must be designed properly in order to achieve this design goal.
