Data logger project
potatohead
Joined Feb 21, 2019
17
I am looking to use this data logger for a small project. I need to be able to read positive and negative voltages but it uses 0-5 V inputs.
Is there was a way for the analog inputs to be referenced to 2.5 V, allowing me to input a +/-1 V sensor? Anyone familiar with the board they are using for the data logger and know if it has such a feature?
The solution would look something like this:
sensor voltage = 0 V, data logger sees +2.5 V
sensor voltage = 1 V, data logger sees +3.5 V
sensor voltage = -1 V, data logger sees 1.5 V
Dean
KeithWalker
Joined Jul 10, 2017
2,804
Dean
Yes, you can do that. Insert a stable, low current 2.5V DC supply between the common reference of the signal and the common reference of the supply. Make sure that they are not both grounded. The accuracy of the results will depend on the stability of the supply.
potatohead
Joined Feb 21, 2019
17
Thank you, would this be as simple as just putting a voltage regulator to the 5 V supply and connecting it’s output to the analog input along with the signal? So the input will see [(signal)+(2.5)] volts.
Or have I missed something?electronics is not my main occupation
potatohead
Joined Feb 21, 2019
17
I don’t think I am correct above. Maybe the voltage regulator is acting like a pull up resistor but on the common ground and pulling up to 2.5 V instead of high/low.
