Data generation system with changing levels
Sergi Martori
Joined Nov 22, 2018
10
Hi everyone!
I'm trying to make a LIN transeiver in order to perform a more huge system, this is a data generation sub-system.
Let's illustrate that:
Well, I'm having a lot of trouble with the "SW1" and "SW2", the power supplies are able to go from positive to negative voltages (to -10 to +40) in controlled steps, but I really don'y know how to make that switches, i'm totally lost, someone has an idea to do that?
maybe some useful data:
max transmission speed: 20KHz
Max Recessive voltage: 42V (actually, for the moment is just 20V)
Min Recessive voltage: -6V
Max Dominant voltage: 42V (same)
Min Dominant voltage: -6V
Normal LIN transmissions levels are dominant voltage = 0 and recessive 12V.
As you can see, the major problem are switching with a negative voltages, for example if Vdom=-5.4V and Vrec=0V
Thanks in advance!
EDIT: I've been searching, maybe something like a triac will work? (http://www.farnell.com/datasheets/1786033.pdf)
EDIT2: more components that may work for this application: "Random Turn-On Solid-State Relays" like this one: http://www.farnell.com/datasheets/1682136.pdf. I think one of these should work, sorry, I never had to use this type of components...
