hi , i am trying to connect output of DAC0808 i.e its 4th pin to LM324 ,i want to get output of LM324 to be negative . now when i give positive voltage at Vref(+) i.e pin 14 of DAC of dac i get a positive voltage at output of LM324 ,but when i give negative voltage on this same pin i get zero output of LM324.
similarly when i give negative voltage at Vref(-) i.e pin 15 i get positive output of LM324 and gving a positive voltage at same pin gives zero output.please help
in proteus it is runing the proper way i want but i am facing this issue in hardware.proteus file is attatched
