"D78F0533A" 64 pin MCU, how to read and write flash memory of this chip?
zahirul_ahsan
Joined Aug 11, 2020
Hello everyone, good day to you. I am working in an air conditioner manufacturing industries in Bangladesh. Sometimes from customer we are facing circuit problem which needs to be replaced. I can read write 8~32 pin MCU easily using RT809H programmer. But now we are in advance technology for INVERTER controlled IC which are 44 pins, 64 pins and 100 pins. I need to read and write the flash memory of these MCU. Is there any way I can do this?
jpanhalt
Joined Jan 18, 2008
11,088
Welcome to AAC.
Look up 3M Textool burn-in sockets. They are for bare chips. Here is one source: https://www.digikey.com/en/product-...kets from,product range and options available.
There are imitators on eBay and elsewhere.
However, if the chip is in circuit,there are usually programming connections/pads provided for it. For the pads, "pogo" pins are often used, but there are other ways to connect to them..
zahirul_ahsan
Joined Aug 11, 2020
Welcome to AAC.
Look up 3M Textool burn-in sockets. They are for bare chips. Here is one source: https://www.digikey.com/en/product-highlight/3/3m/textool-custom-sockets#:~:text=Custom Textool BGA sockets from,product range and options available.
Is it possible that MCU is locked by the manufacturer? and I can not read write....
