d/a converter with negative voltage output
childs72
Joined Jul 3, 2005
22
is there any ic which is d/a conrverter with negative volatage output available on the market? if not, is there any circuit to realize this output? need help!!!
22,102
[post=15648]Quoted post[/post]​
Sure Maxim has boatloads of them.
Maxim Website
What are some of your other requirements so we can narrow the field from several hundred down to a small handful?
dtiger2k
Joined Mar 29, 2006
10
Here are a couple of links, the first is a a datasheet for a low-cost versatile D/A converter with a ± 10v, ± 5v, and ± 2.5v output. The second is a link to Analog Devices web page to search for other D/A converters if this doesn't work for you. Hope this helps.
ADDAC80
Analog Devices
I wanted to add that the above (ADDAC80) might be a little expensive if this is just for a small project. There are D/A converters much cheaper. You can also go to Digikey and type in DAC in the search field. Then choose D/A converters, it will let you search by criteria that you select for the IC. You can also check out datasheets from the Digikey site.
