Cycling Through a Series of LED's with Each Button Push
Sir Kit
Joined Feb 29, 2012
213
I have a momentary button that pulls low to trigger individually, in sequence, a series of 6 logic functions. So I know what function has been triggered, I would like the button to also cycle individually through 6 LED's, returning to the first upon the 7th push.
Can someone please tell me what type of circuit would do this. Available power is 12VDC.
wayneh
Joined Sep 9, 2010
18,164
Thanks. Just two questions please.
What is Vcc? Is there any way to eliminate the LM317?
Yes, the LM317 is not needed. A current-limiting resistor for each LED is the more typical solution. Vcc is just the voltage of your power supply.
dl324
Joined Mar 30, 2015
18,467
Not critical. Anything that visibly lights up.
CD4017 outputs will source 1-2mA with a 12V supply. If you don't use more than that, you don't need extra circuitry to drive the LEDs.
Loading the outputs won't affect correct operation of the counter.
Sir Kit
Joined Feb 29, 2012
213
I would use a CD4017 as shown below. The LM555 would be replaced by a momentary switch.
If Vcc is 12VDC can I feed that straight into the clock input? If that is too high, I also have 3.6VDC in the circuit. Would that be too low?
Given the 12VDC Vcc, what would the voltage output to the LED's be?
In response to crutschow, the LED's only need to indicate the number of times the momentary switch has been pressed. For example, after six pushes the sixth LED lights. One more push and it restarts at number one.
dl324
Joined Mar 30, 2015
18,467
You'll need to debounce the switch.
CD4017 will operate from 3-18V. As long as the clock signal isn't greater than Vdd it will work.
Logic HIGH will be about Vdd.
Typical source current at 10V is 2.6mA, but can be as low as about 1mA (at 125C). Assuming a 2V forward voltage for the LEDs (depends on color), 10k would give you 1mA.
wayneh
Joined Sep 9, 2010
18,164
Debouncing the switch will be critical to prevent each press from counting as many make-break counts. A 555 is good for debouncing but it can be done fairly well with just an RC filter.
38,814
A simple debounce circuit from the switch is an RC filter as wayneh mentioned.
100kΩ in series with 1uF to ground at the clk input should be sufficient.
To protect the input from excessive current from the cap when power is suddenly removed, add a 1kΩ in series with the input after the capacitor (below).
