Medium Voltage Cable Heat Cycling Test Circuit Example?
HighVoltage!
Joined Apr 28, 2014
182
Good Day,
I am trying to simulate a medium voltage cable Heat Cycling Test on PSPICE. I am aware that the low resistance, shorted bare conductor end, acts like the secondary winding of the transformer (shorted cable). What electrical information would I need in order to simulate? How would I simulate?
Possible information that is needed:
Primary Side:
Inductance & Resistance in series? Volts per turn?
Secondary Side: Resistance, inductance, & cable capacitance?
Here is an example of a transformer used for such purpose:
https://hubbellcdn.com/specsheet/HIPO_ Heat-Cycle-Test-Set_SPEC.pdf
THANKS FOR YOU HELP ON THIS!
